Radio LEDs
Old Aug 17, 2015 | 05:17 AM
TheNewSaaber's Avatar
Default Radio LEDs
I am acquainting myself with my new (old) 2001 9-3 base model, and going about attending the details which always accompany a new car acquisition. I have already replaced a handful of the burned out bulbs in various places, and am looking forward, not without some trepidation, to getting at the ones in the instrument panel. If I end up without any leftover parts once I get it back together, I will consider that something of a miracle.
One of the things I noticed is that the face of the radio is dark, when I would expect it to be lit up. Removing the cover of the radio, I found six LEDs on a larger brown PCB, and one small one on a fairly small PCB card. All of them appear to be toasted, although as a general matter, those devices are supposed to last a very long time.
I can handle the soldering needed to replace them, but I have no idea of what type or value they are. Does anyone know ? Is there a radio repair manual ?
I am asking because of the difficulty involved in getting a radio changed in this car, as a consequence of the whole security arrangement, and I have an aversion to divorces and second marriages. I am told that these are literally the technical terms used to described changing a radio in this car.
Old Aug 20, 2015 | 03:48 AM
I need to revise what I wrote above.
The larger PCB, brown on one side, green on the other, which is marked CMKM-P3X, has 6 very small bulbs on it, each of which is encased in green rubber. The holes where the bulbs sit are marked PL101 and so on, and they have no markings on them that I can see. Each bulb has a pair of leads soldered on to the PCB, neatly placed away from other components so that it would be easy to replace them, if only I knew with what.
Is there anyone with access to the radio repair manual ? I ask because another radio I just acquired has the same board and bulbs, which are also burned out. I suspect the same will be true for any other radios of the same vintage.
The device on the small PCB is indeed an LED, but there is no marking or indication on it either.
Old Dec 3, 2015 | 05:24 PM
Tanin Auto's Avatar
Former Sponsor
From: 7012 State Road 31, STE 100- Racine, WI, 53402
Hi, We are a new vendor on the forum and we would like to offer some assistance on your bulb issue. If we had to guess, they sound like they are 3mm in width, but to make certain, we recommend measuring them so that the bulbs fit your existing green caps. If they are 3mm, then we have what you are looking for here:
3mm 12 volt and 14 volt automotive light bulbs
Hope this helps! We are here if you have any questions at all.
ohpoppy
Nov 19, 2016 02:30 PM
okh390p4n
May 1, 2011 08:26 PM
okh390p4n
Apr 15, 2011 08:52 PM
okh390p4n
1974-1994 900
Apr 8, 2011 08:24 PM
larrympc
Mar 27, 2011 11:18 PM
