rear brake caliper bolts
wow...talk about some thin bolt heads! any tips on loosening the rear brake caliper bolts on a 2002 9-3 I cannot get enough torgue with a socket...there is no room to fit a vice grip ..i have put a bolt release chemical to maybe loosen it ..if you have replaced rear brake pads on this model..you know the dilema..hope you can help!!
gatr2000 |
