Removing the Heater Fan Switch
Old Dec 26, 2008 | 07:50 PM
Mr_boondoggle's Avatar
Default Removing the Heater Fan Switch
Well, I am at a loss as to why my heater fan doesn't work so I think I remove the fan switch and probe around with my multimeter.
How do I remove the fan speed switch?
Old Dec 29, 2008 | 09:52 AM
Default RE: Removing the Heater Fan Switch
The whole panel is held up with plastic tabs on both top and bottom. You need to remove the side panels...last time I did it I had a lot removed because I was fixing a heater core leak, so I don't know exactly what is the minimum of parts removed.
