-   -   Soft Top Hydraulic Pump Connections (https://saabforums.com/forum/saab-9-3-11/soft-top-hydraulic-pump-connections-9718/)
chezhenri@me.com Aug 17, 2016 03:05 PM
I have a 2002 9-3 SE Convertible and recently the roof pump stopped working.
I checked out the pump and found that the reservoir was empty and the oil had leaked into the compartment.
After further investigation I found that one of the pipes/tubes feeding a ram had become disconnected from the pump.
I'm guessing that it not as simple a fix to push the tube back into its connector as it works under high pressure.
I am looking on advice/instructions on how to reconnect the tube securely to the pump.
Thank you in advance for your help.
