stereo ?????
Radio,Tape and CD not working on 97 900SE Turbo Conv. I just bought any Suggestions?
does it power on at all? Check fuse first.
If it doesn't power on - check the fuse.
RADIO -- working now!
:) The dealer in Jacksonville, FL. Explained for FREE, that the code is on the back of the unit. Pull unit out with DIN plug puller ( get it at Parts store or hanger can be used ) 4 digit code entered it works!!! If code entered is accidently entered wrong, you must clear code by pressing and holding BAND until 'CODE IN' appears in display. That was my problem. The ex-owner put in wrong code and even when i put in correct code, it did nothing. You have to clear the mistake and wait until it tells you to enter the code. Finally MUSIC !! Hope this helps someone!!!!:D
body moulding
I am looking to replace a missing piece of body moulding! The black plastic moulding that is in front of rear passenger side. Runs up from bottom to the side moulding that runs across the car. Anyone know where I cam get this ON-LINE, with out going to the dealer. THANKS in advance !!!!
car-part.com
AM radio reception
Any suggestions on how to better my AM reception on my 1997 Saab 900SE Turbo Convertible!! FM is great, but AM is terrible.:confused:
| All times are GMT -5. The time now is 04:45 AM. |
