Throttle body error 1251 and 1253 (9-3)
I am still at a loss to resolve a Throttle Body issue. I was getting an error 1251 and 1253 both pointing at the Throttle body but I just put in my second BBA rebuilt unit and still will not function out of Limp mode. I am having problems believing it is the Throttle Body at this point.
Does anyone know what else could cause this problem other than the Throttle Body? |
RE: Throttle body error 1251 and 1253 (9-3)
have you tried clearing the codes and see if they reappear?
When installing a new throttle body (T7):
1: The codes must be cleared. 2: The throttle body must not be in mechanical override mode (limp mode) If the codes have not been cleared, the moment you turn the key to the ON position it will trigger the mechanical override on the TB. Likewise if the codes have been cleared but the TB has not been reset, the moment you turn the key to ON it will throw a code. |
OK the second remanufactered throttle body failed after a few weeks and could not even get it to reset. So its going back for a refund but I need to know if anyone out there can think of anything the could be causing the throttle body to fail other than just a bad one. my gut is telling me it may be something more than just bad luck. Are there any relays that play a part (since I have found a few in the wrong spots, could the computer have anything to do with it??OK, I am going to try one more time. I will first, turn key on and clear the codes. I will then remove the key and reset the throttle bodyand finally, I will try to start the car (and pray..) |
9.3 throttle body: repeated failure
I'm wondering if you ever figured out why the throttle body was repeatedly failing. I have a 2000 9.3 and I am about to have a new one installed after failure of 2 reconditioned ones.
Originally Posted by roadvision
(Post 4271)
