Ventilation problems - 2004 9-3
Hello everyone,
I have a 2004 9.3 1.9 TDI Liner. I have a intermittent problem with the ventilation and heating. Sometimes the air direction switch does not work and at the same time the temperature button only puts out hot air, even when you put it onto cold. If you turn on the air con then cold air comes out. This obviously causes problems with the car steaming up, especially in the current cold weather! I have taken it to my local saab dealer and they could not find anything wrong! Has anyone else had this problem or do you know how i might be able to fix it. Cheers |
