-   -   water on top of engine??? (https://saabforums.com/forum/saab-9-3-11/water-top-engine-2618/)
gatr2000 May 16, 2010 05:21 PM
cranked the 2002 saab 9-3 yesterday and the car sounded like it was having an asthma attack ... popped the hood and there is water over the battery, main air flow hose, casette cover on top of engine and the hood liner is wet. the water is clean with no antifreeze mixed in. you can hear lots of popping when trying to crank i am sure electrical components are wet...not holes in the hood!! the undercarriage appears dry..letting it dry...anyone have this happen? a water pump leak would have a mix of anitifreeze right?
please advise...
gatr2000 May 17, 2010 05:22 PM
after the rain last night i have concluded the leak is from the hood...the car is drying out...the car is turning but doesn't sound normal...not sure where to start! engine code 304 cps i replaced this and the car sounds diferrent when trying to crank
