xenon lights going pink
It also happen to me once and i would try to come back on and quickly cut off. I suggest change the both both bulbs with each others. Yes change the passenger side to drive side and driver side to passenger side and see the the problem moves with bulb. Then may be you find the problem. Gud Luck.
I think pink xenons would be sweet though
