02' Front-end vibration when hit bumps
Greetings,
I am new to this forum and first time posting. My 02' drives straight and doesn make any noises. However, I feel this light vibration across the front-end travels up to my steering wheel whenever I hit a big bumps or railroad tracks. My sway-bar end links were bad and I had that replaced and hoping that the vibration would dissapear as well, but it didn't. The tires are good and has even wear. I haven't had any alignment done or need to at this point. Please keep in mind, the vibration issue only appears when I go over a bump or pot holes. Please share info and how to remedy this problem if you had this vibration issue before. Thank you in advance. Jat |
