1999 9-5 Turbo
Does anyone know were I can find a rebuilt 9-5 V6 long block engine
RE: 1999 9-5 Turbo
What happened to your engine? Timing belt?
RE: 1999 9-5 Turbo
Yea timing belt, then the piston took out a valve and you can image whathappened from there.
RE: 1999 9-5 Turbo
Is there any damage to the block? Was the piston damaged? If anything I'd rebuild the damaged head, it'll be MUCH cheaper than a rebuilt engine. Believe it or not, but that is a very common failure on the V6s and I've been lucky finding good deals on parts for that particular repair.
RE: 1999 9-5 Turbo
yea i will probably check into that. I have not done a complete tear down on this engine yet
RE: 1999 9-5 Turbo
Go ahead and take the heads off. You've got nothing to loose except a couple of hours of time. I've seen three rebuilds of these engines and it's usually a matter of a couple of valves which are around $10 each...plus new headgaskets and timing belt/tensioneer of course
RE: 1999 9-5 Turbo
do you a good source for these parts?
RE: 1999 9-5 Turbo
RE: 1999 9-5 Turbo
Thanks for all the help I will let you know how it all turns out
