2002 9.5 2.3l check engine code P 1110
I have a P110 check engine code. There ar no sysptoms and the car seems to run fine. DO I need a new gas cap or what. The guys at Auto Zone who read the codes said it was a manufacturers code and they couldn't translate it.
that's a possible, PO110 ,a air intake sensor error code,check and clean/replace air cleaner and clean sensor with spray cleaner do not damage it
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0110 Intake Air Temperature Circuit Malfunction P0111 Intake Air Temperature Circuit Range/Performance Problem P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature Circuit Malfunction P0116 Engine Coolant Temperature Circuit Range/Performance Problem Downloaded from www.OnboardDiagnostics.co.uk |
Originally Posted by fwitt1
(Post 15347)
You can find engine codes details here : Check Engine Codes, Trouble Codes, OBD2 Codes, Diagnostic Codes - CheckEngineCode.com |
(Post 15347)
