-   -   9 5 transmission slip (https://saabforums.com/forum/saab-9-5-12/9-5-transmission-slip-2642/)
the grants Jun 6, 2010 08:27 PM
new to saab forum, just purchased a 99 95 with 75000, bought it knowing that trany began slipping on past owner while driving on highway, he always serviced car , i am wondering if tranny has a pick up screen incase it may be clogged or possible tranny cooler problems? thanks brad in ill.
IGUANA Jul 2, 2010 10:32 PM
Wecome Brad in Ill. Time for a tranny I'm sorry to say.
stratman3 Jul 21, 2010 02:48 PM
Are you sure it's slipping or maybe going into limp mode?
the grants Jul 22, 2010 07:35 AM
i do not know what limp mode is? the car completely stopped moving but after it sat for about half a hour it would again move do you know if the transmision has a coller and it overheats? it happened on the highway thanks brad
stratman3 Jul 23, 2010 05:53 AM
Limb mode is when the tranny control module senses a problem and defaults the tranny to 3rd gear. The car will still drive but very slow start like it's slipping. Are you getting any gear light or check engine light? These trannys don't have a filter or at least one that can be serviced, notice there is no pan.
the grants Jul 24, 2010 09:34 AM
i will check for gear light , and check engine , i dont believe either though i have tryed to drive car on highway but it did drive short distance with no problem , brad
WWEEKES Sep 12, 2010 11:06 AM
Im getting the same problem, i have a gear light and check engine light on, replaced the tranny with a junk yard trans and same issue!!!
the grants Sep 16, 2010 09:43 PM
i am not getting any gear or engine light, drove car about 1-2 miles no slip but revs to about 3500 before shifting out of 1st and second , seems to wind out when turbo kicks in, service security alarm is lit on screen , is it possible computer for tranny ? it is cooler now, wondering if tranny is not hot enough to slip? any help appreciated! brad in il.
stratman3 Sep 17, 2010 09:32 AM
Simple things to check first, tranny fluid level. If that's within normal, check for codes. Before diving into an expensive rebuild, its worth trying a flush.
the grants Sep 18, 2010 06:01 PM
thanks for input, what type of fluid would be good (lucas)? and where to check codes brad
