-   -   headlight problem (https://saabforums.com/forum/saab-9-5-12/headlight-problem-3536/)
eliot Dec 31, 2010 12:40 PM
headlight problem
Hi there, I have a 99 9-5 which is having problems with the headlights. I already checked the relay and it seems to be in good condition. Checked all the circuits and everything seems to function properly. I am now looking to find what else could be the problem, any ideas on what I should check? Thanks!
Roto Dec 31, 2010 05:09 PM
Do they just not turn on? Will they turn on to high beam?
eliot Jan 1, 2011 11:59 AM
Only one of the high beams and only one of the low beams will turn on. These are on opposite sides. I checked the fuses already too.
Roto Jan 13, 2011 09:49 PM
Try swapping the bulbs from left to right. If the low beam and the high beam still turn on on the same side before the bulb swap than it can be wiring or the socket, if not - just change the bulbs.
