trunk latch--Saab 9-5
Old 04-11-2008, 08:13 AM
mglofgren's Avatar
Default trunk latch--Saab 9-5
suddenly our trunk won't close on our 1999 9-5 wagon. the trunk door latch will not open, even though you can hear it trying to open when you use either the key or the trunk button on the driver's door. any help on what's wrong, or at least how i can manually open latch to close trunk door?
mglofgren is offline
Old 11-13-2014, 10:43 AM
Embarber9's Avatar
Did you ever get a response for this? I have the same problem with my 1999 9-5 wagon.
It happened in the cold, if that makes a difference.
Embarber9 is offline
Old 04-13-2019, 10:33 PM
Ben Groseclose's Avatar
Default Getting wagon trunk to stay closed.
The wagon door is in the latched position AND is open at the same time. This means the closed latch will not secure the door when you try and close it.
To fix: push the button on the remote control releasing the latch WHILE using a screwdriver or some other tool to manually pull the latch open.
You have to do both at once.
Now close the door and it should latch perfectly.
Ben Groseclose is offline
saab93dad
09-12-2014 11:03 PM
enstock
12-10-2013 05:47 PM
feralblue
10-10-2011 02:34 AM
kiml
02-28-2008 10:26 AM
jeff1785
12-07-2007 03:21 PM
Quick Reply: trunk latch--Saab 9-5
