P1925
I'm getting a P1925 code. Speedo goes to zero, ABS, TCS, check engine & exclamation point all on. Comes & goes. My local Saab guy a bit stumped, and afraid it's an ABS module failure (a $2000-$2500 job !!) I see something on the forum re dirty ABS sensors, I'll see if he can check that. Any other ideas? Thanks
2000 9-5 Aero. |
RE: P1925
start with sensors first...
RE: P1925
What was the final solution to this problem? My 2000 9-5 Aero has the same symptoms.
abs lights
i have been told by the man that i bought my wifes car it is the module
if you want i can send you tell you the info he told me first and for most have system scanned and make sure that is the problem first then look on like sites like www.thesaabsite.com and then also on ebay but you must have the bosch number that is on your module that you can spy with a exstendable mirror but look on ebay choco |
| All times are GMT -5. The time now is 04:45 AM. |
