wirning diagram shift interlock relay
Old Jun 19, 2025 | 07:14 PM
Justin Raney's Avatar
Default wirning diagram shift interlock relay
Does anyone have the shift interlock wiring diagram? The shift interlock switch operates off the same brake pedal switch as the brake lights or the cruise control brake pedal switch? Theres a relay in the engine compartment is it 85-86 for the brakes lights or shift interlock? Im trying to find out why the shiftlock mechanism stopped functioning. Its a green and grey wire from one of the brake pedal switches to the shift interlock only im not sure if there is a fuse or relay in between or after the pedal switch to test for power and ground or to jumper wire, power probe. Im trying to see if the brake pedal switch is bad or the shiftlock electromagnetic mechanism.
Christian Smith
Jun 27, 2020 03:50 PM
jackraider
Mar 18, 2015 04:30 PM
djborden
Nov 16, 2009 04:56 PM
Tetzlaffino
Jul 11, 2007 09:01 AM
nhrvatin
Dec 16, 2006 05:31 PM
