1992 turbo with leaking fuel line
i'm not an expert on cars at all but i have a 1992 saab 9000 turbo i got from my aunt because the fuel line started leaking. there is a hole in it and i've tried to look it up how to fix it and get absolutely nothing. i've looked up replacing the whole fuel line and it's like nothing of that sort exists. it's soo aggervating. does anybody have any idea how i could fix it??
replace it with 40+ psi rated fuel line from fuel pump to rail and from regulator back to tank
you can try hitting up a local speed shop or a hydraulic shop for a consultation. It's fairly straightforward...some cut-on-the-spot braided fuel hose with crimp-on fittings wouldn't ruin your budget either.
earls indy supplies goodridge braided hose for $3.00 per foot , and normal rubber line for 89 cents per foot
