-   -   86 Saab 9000 Turbo Clutch help needed (https://saabforums.com/forum/saab-9000-27/86-saab-9000-turbo-clutch-help-needed-9086/)
BTVelocity Aug 10, 2014 01:43 PM
Just joined the Forum and have not been able to find a discussion on how to replace the Clutch Slave Cylinder in a 1986 Saab 9000 Turbo. My clutch suddenly lost all pressure while driving. The tell-tale sign is hydraulic fluid now leaking from under the clutch bell housing area and the brake fluid reservoir losing fluid. No other fluid leaks found.
Can anyone point me to a thread with a step by step description on how to replace the Clutch Slave Cylinder on an 86 Saab 9000 Turbo? I also don't mind rebuilding it with a seal kit, but I still need to figure out how to get it out. Photos or videos describing the procedure would be awesome.
If nothing is available on the Forum, I would appreciate a referral to any resources that I could use for this procedure, even if they are outside of the Forum.
Thanks!
