ABS light
Old Mar 2, 2009 | 12:13 AM
jhacen's Avatar
Default ABS light
My 1997 Saab 9000 CE turbo has ABS light on when I drive but not when I start it. The minute I put it on first or reverse the ABS light comes on. What's wrong with the ABS?
Old Mar 2, 2009 | 08:20 AM
boostpowered's Avatar
take it to advanced auto parts and ask them to retreive you abs codes they will do it for free
Old Mar 2, 2009 | 08:25 AM
jhacen's Avatar
Thanks, boostpowered! I will bring my car there tomorrow as it's still snowing here in NY.
Old Mar 5, 2009 | 08:30 PM
jhacen's Avatar
I went to auto zone and they did not have the instrument for the code. The guy told me that I need a new sensor and that my ABS is not working. He said that I have to pump my brakes when braking.
Old Mar 6, 2009 | 07:55 AM
go to advance auto , auto zone is lacking in the euro dept
Old Mar 16, 2009 | 04:12 PM
dagger dog's Avatar
jhacen,
The most likley problem is a wheel speed sensor, since the light doesn't come on 'till you start to move, but as boostpowered states you will have to get the code read before you can be sure, and also so you can tell which of the 4 sensors could be bad. There is one for each wheel , the abs controll module receives signals from each sensor, the module self checks for problems each time the key is cycled, then when you start the car moving it checks the wheel speed sensors, if a signal from one of the four is not present the malfunction light illuminates.
Once you find out what sensor is malfunctioning it is fairley easy to replace.
But all this won't do any good until you have the codes read.
terryg911
Nov 27, 2011 11:53 AM
okh390p4n
May 1, 2011 08:26 PM
okh390p4n
Apr 15, 2011 08:52 PM
chriswalstra
Feb 18, 2011 10:11 AM
tony
Aug 9, 2010 10:49 AM
