-   -   Power Steering Pump (https://saabforums.com/forum/saab-9000-27/power-steering-pump-8604/)
reidg Feb 28, 2013 04:12 PM
Power Steering Pump
Hello,
I've replaced my power steering pump on my 1994 Saab 9000 Turbo..
All is good and my power steering is back, except for inside the resivoir.
There is a geyser inside and it causes the fluid to be airrated..
Is this a problem of an air bubble in the system - and/or has to be bled properly?
I'm not sure of a bleeding procedure..
Anyone have insight?
Thanks
Roto Mar 1, 2013 06:07 AM
Sounds kind of odd. I ran the system completely dry before and simply filled and it primed itself fine and ran fine. Errr, are you sure your hoses are hooked up correctly? Nothing I can think of in there should be causing a geyser.
reidg May 28, 2013 09:31 PM
Yeah I only had the inlet and discharge to re-connect
and it's impossible to mix those up..
But yeah it was completley empty too... oh well ill just live with it for now
Thanks Roto
