Solonoid...
Im concerned if the saab 9000's run better or worse without the solonoid in. see... i have a custom intake and a boost controller which takes the spots of all 3 lines that connect to the solonoid so.. right now im running without a solonoid.. my car pulls fine and runs good but for some reason it doesn't feel as smooth as before. anyones input would be great... is there a way i can have the solonoid installed with the boost controller and new intake line? maybe put a T in and connect that way? thanks.
-Ryan |
RE: Solonoid...
its rough because your computer isnt controlling it
RE: Solonoid...
It's fine running without the soldenoid connected, the only thing you loose is electronic boost control and the ability of the car to cut the boost in case of a failure.
