9-5 4cylinder turbo cranks but won’t start. My mechanic needs Saab mechanics help
Help. My Saab just died at slow speed. Put new battery in because old one was dying. Started after several days trying simple trouble shooting. I’m not a mechanic but tried basic stuff found on forums. Ran 2 days then back to no start. Took it to mechanic thinking vacuum hoses needed replace, several looked pretty bad and ordered a new ingnition coil pack. He went through it and needs clarity on a few things.
Does the ignition coil ground through the trionic module? Is the trionic module 1 module or 3 separate modules? TRIonic?
He is measuring 107 kohms with ground on and only .2 with ground off.
Also he is getting 1.3 to 0 volts at mass air, temp, and crank sensors.
Also, don’t know if related, but right before this the heat and air went out. No flow and I had bought a new blower fan but had not put it in yet. Any help or ideas are appreciated! Thanks!
flynn
Jan 29, 2013 08:37 PM
