-   Saab Forums Help & Suggestion Center (https://saabforums.com/forum/saab-forums-help-suggestion-center-7/)
-   -   9-5 4cylinder turbo cranks but won’t start. My mechanic needs Saab mechanics help (https://saabforums.com/forum/saab-forums-help-suggestion-center-7/9-5-4cylinder-turbo-cranks-but-won%92t-start-my-mechanic-needs-saab-mechanics-help-10085/)
docscobee Apr 9, 2021 03:13 PM
Help. My Saab just died at slow speed. Put new battery in because old one was dying. Started after several days trying simple trouble shooting. I’m not a mechanic but tried basic stuff found on forums. Ran 2 days then back to no start. Took it to mechanic thinking vacuum hoses needed replace, several looked pretty bad and ordered a new ingnition coil pack. He went through it and needs clarity on a few things.
Does the ignition coil ground through the trionic module? Is the trionic module 1 module or 3 separate modules? TRIonic?
He is measuring 107 kohms with ground on and only .2 with ground off.
Also he is getting 1.3 to 0 volts at mass air, temp, and crank sensors.
Also, don’t know if related, but right before this the heat and air went out. No flow and I had bought a new blower fan but had not put it in yet. Any help or ideas are appreciated! Thanks!
