-   Tuner's playground (https://saabforums.com/forum/tuners-playground-31/)
-   -   info you may not know. (https://saabforums.com/forum/tuners-playground-31/info-you-may-not-know-1556/)
boostpowered Feb 20, 2009 01:01 PM
saab turbos by year:
85-89 garrett t3 tb0356
89-90 w/o cat td05
90 w cat t25
91-93 except aero with manual trans t25m
93---td04
fuel tank capacity
85-89 68liters
90-92 on 66liters
91 only 62liters
torque specs lb foot
crankshaft position sensor 6
exhaust manifoild to cylinder head 18
exhaust manifold to turbo --
t3/te05 30
t25/td04 16
exhaust flange joints 30
front exhaust to turbo 18
intake manifold ---
b202 13
b234 16
intercooler to condensor bolts 6
lambada sensor 41
oil cooler upper union bolt 13
bosch part#s these are for the b202 only
alternator # al129x
amm # 0280-212-013
ecu # 0280-000-566
overboost cutoff# 0280-142-103
fpr #0280-160-255
coolant temp sensor #0280-130-055
coil#00054
cap#03010
rotor #04168
ignition amp#0227-100-139
vac advance#07220
oil filter#3330
02 sensor oe#13957---universal#15735
plug wires #09237
starter #sr32x
water pump#97109
apc# 7517477
distributor new#0237-507-008
