Intermittent Starting
Old Aug 23, 2010 | 03:49 PM
we5martins's Avatar
Default Intermittent Starting
I have a 92 900 non turbo. I am encountering intermitten starting. Always starts in the am but if I were to drive a bit, car get warm, it will not start again.... After a few minutes of turning ignition key usually it will finally turn over and start right up. I can hear a pop and then nothing. The battery is good, cables seem fine, new starter and solenoid, replaced a piece of bad wiring to ignition switch, cleaned all contacts on ignition switch. If I try to jump the car when it is in no start mode it will crank right up. Need Help.....ignition switch is the only part in link I have not replaced, (need the special tool to loosen screws)????
frriveramd
May 16, 2010 06:55 PM
ode
Aug 18, 2007 11:21 AM
blane17
Apr 20, 2007 11:37 PM
shiftatpier44
Feb 8, 2006 12:52 PM
pp
Jan 25, 2006 12:44 PM
