Oil pushing out of dipstick tube
Old May 4, 2010 | 12:43 PM
029-3SE215hp's Avatar
Default Oil pushing out of dipstick tube
Hello to all.
I have a 2002 9-3 Se with a unique (at least to me) problem. The vehicle runs poorly and has oil being pushed up the dipstick tube. I assumed blow by from cracked pistons or rings but compression is correct across the cylinders.
I tried disconnecting some of the poorly designed crankcase vent hoses while running and now there is smoke coming from the whole in the valve cover.
I am now thinking:
bad turbo
plugged oil trap
clogged cat
Any ideas or previous experiences will be of great help. I would rather not tear this thing down unless I have too. Sludge does not look to be an issue with this car. 72k and dealer maintained. Thanks for any and all replies.
Old May 6, 2010 | 09:52 AM
UPDATE
The car has blow by due to bad rings on cylinder 1.
I am thinking I had a false compression reading because there was oil stuck in the cylinder, raising the reading.
Upon dis-assembly, I found that the oil rings were seized in the piston because of sludge, and the bottom compression ring was actually broken. (See pic)
I now plan to hone the cylinder out and replace the entire piston and ring assembly with a used one from off of the shelf, (I have two parts motors).
I was thinking of going B204 pistons because I hear they are stronger. Any ideas or things I should look out for. Thanks.
Attached Thumbnails Oil pushing out of dipstick tube-0506101044-00.jpg   Oil pushing out of dipstick tube-0506101045-01.jpg
chezhenri@me.com
Aug 17, 2016 03:05 PM
Roto
Oct 24, 2015 09:22 AM
ssanchez
May 19, 2015 02:38 PM
Asldhjkf
May 24, 2010 05:37 PM
