vacuum leaks
Old Jan 20, 2009 | 05:36 PM
Mr_boondoggle's Avatar
Default vacuum leaks
What do you know about finding vacuum leaks?
What is the best to locate a vacuum leak?
How does a professional shop find a vacuum leak?
Old Jan 20, 2009 | 05:59 PM
Default RE: vacuum leaks
The most commonly used way of finding a leak is spraying carb cleaner on the vacuum hoses and listening to the engine change RPM when you hit a leak. I don't do that however, I simply replace all the hoses periodically. There's only what? 6 vac lines on the car? About 10' of silicone hose fixes it. If it's not a hose than carb cleaner works I guess. My mech simply finds them by ear.
Old Jan 23, 2009 | 07:26 AM
boostpowered's Avatar
dish soap in a spray bottle the leaks will bubble
Old Jan 31, 2009 | 12:29 PM
959kaero's Avatar
i found a crack in my vacuum line that on the fenderwall near the battery its the one that comes off the lil 3 ended thingy pointing towards the firewall but it goes under the battery and is shrinkwrapped so i dont know where the other end of this line goes too to swapp it out my saab is a 1995 9ooo aero anyone know?
Old Jan 31, 2009 | 07:42 PM
Saab Fahrer's Avatar
Carb cleaner is the quickest, but if I can't find it with that and I'm sure there is one, then I break out the smoke machine. Its mostly used for EVAP emissions leaks, but works great for vacuum leaks too.
Old Feb 1, 2009 | 10:18 AM
if i am correct that line that goes through your false bulkhead runs to the boost gauge and the over boost protection switch
Old Feb 1, 2009 | 01:38 PM
959kaero's Avatar
thank you boostpowered is there any chance you can tell me where that is cause what i guessed it was was the hose that went to or came from the big plastic thing that points at the radiator very close to the fan and thats what i connected it too but i dont want to break something and yes the car scoots a bit more it doesnt woosh like it did before
can you where this unit is or what to look for so i can hook it up correctly plz?
Old Feb 2, 2009 | 07:32 AM
post some pics it will help diagnose the problem better . are you talking about the apc with three silicon lines sitting on the drivers side above the radiator fan that has a electrical connection that is essentially your boost controller
Old Feb 2, 2009 | 04:58 PM
959kaero's Avatar
after my hangover wore off i reread your post and i understood it alot better got inside the false bulkhead and re ran the hoses to their proper spots everything is working properly now^^ty for the help
cyndigerl
1974-1994 900
Nov 3, 2021 09:17 AM
Canada_Saab
Nov 6, 2016 09:36 AM
Juan Vite
Oct 15, 2016 08:54 PM
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
ThePoisonDonut
Sep 22, 2016 07:49 AM
