HUD message?
Old Dec 19, 2009 | 01:17 AM
alexanderzx1's Avatar
Default HUD message?
Tonight a message showed up saying that my left brake light was not working but on inspection it is working fine. Does this mean that a sensor is going bad? Can i make it so the message does not come on every time at startup?
Old Dec 19, 2009 | 07:33 PM
are you sure it works for both brake and marker?
Old Dec 20, 2009 | 07:34 PM
ridfiend's Avatar
This same thing happend to me this summer. The tail light was functioing fine and the warning message appeared. I verified that the light was working and then hit the clear button to make the message go away. about two weeks later the light stopped working and the message appeared again...this time with additional warnings (directional light failure, brake light failure, etc.) all three lights in the cluster had failed. The newer saabs can sense when a light is about to fail. I think that's what is happening to you.
Roto
Mar 24, 2016 01:37 PM
Snyderg167
Apr 23, 2014 06:07 AM
kyblusaab
Jan 21, 2011 10:27 PM
tallguy04
May 31, 2009 08:26 AM
