HELP! total dashboard craziness! Follow up to rear wheel hubs!
Old Apr 28, 2009 | 10:17 AM
the blaab's Avatar
Default HELP! total dashboard craziness! Follow up to rear wheel hubs!
When it rains it pours!
So I check tire pressure filled up the tires evenly with air and checked the hubs by seeing if there was any play in the wheels, nothing seems to be a miss but the noise still exists...
BUT get this:
We drove about 10 minutes and then the following lights went on on my dash:
WARNING CHIME GOES OFF AND WE GET:
Large red triangle with exclamation point
TCS light
"TCS off" light
ABS light
BRAKE light in yellow circle
Check engine light
Speedometer stopped working
Pulled over seemed to be idling a little rough but not too bad, may be a coincidence.
Then we turn around to go to go home and call my mechanic....after about 10 minutes all of the lights go back out, the speedo goes back on...but the check engine light STAYS on...
Thoughts??
Matt Winkler
Old Apr 28, 2009 | 10:36 AM
First of all get the CEL pulled and post the code back. The TCS light and the Speedo stopping working means that the wheel sensor connections need to be cleaned...may be it is related to your hub noise since the wheel sensor is part of the rear hub assembly. First try to clean up the contacts on those sensors...
Scrapes High
Feb 28, 2016 03:29 PM
dancingbalu
May 23, 2014 01:48 PM
Saab Fahrer
Mar 12, 2009 04:53 PM
boostpowered
Feb 5, 2009 01:21 PM
Spy10021
Aug 24, 2008 03:50 PM
