Headlight Relay??
Old Oct 28, 2010 | 07:16 AM
raboni's Avatar
Default Headlight Relay??
On my 2005 9-3 Arc, I got the low beam failure message, and the left (driver) side headlight was out. I replaced the bulb but still no light.
I have read about Saab's having a headlight relay that can be faulty. Is there a relay on my model, where is it (engine compartment fuse box?), and what is the id of the relay (e.g. R15)?
Thank you
Old Oct 11, 2012 | 04:01 PM
drmikevasovski's Avatar
My driver side high beam light went out 3 times! Checked bulb (not burned out and seated correctly in the socket) and fuse (pulled it out and confirmed it's not burned through) and each time the high beam light came back but only for one day. Changed the high beam head light relay $13.00 part (Duralast part #19273 at Autozone) and problem solved. At least so far. The id (diagram) of the relay is on the inside cover of the fuse box in the engine compartment.
Old Oct 16, 2012 | 02:43 AM
JovitaLeal's Avatar
Susanna Conway
Oct 23, 2016 03:46 PM
jlittle900
1974-1994 900
Sep 10, 2016 06:53 PM
PTC_MAX
Jul 15, 2013 10:53 AM
redman73096
Aug 18, 2012 08:07 AM
Mountain man
Aug 1, 2009 04:55 PM
