exhaust smoke
Old Dec 13, 2008 | 12:58 AM
saabpower's Avatar
Default exhaust smoke
i have i question every time i start my car i get blue ish white smoke from the exhust and after i let it idle for a while it goes back to normal anny advice
Old Dec 13, 2008 | 09:12 AM
boostpowered's Avatar
Default RE: exhaust smoke
its just condensation its quite normal especially in the morning
Old Dec 21, 2008 | 07:14 PM
GarrettCharger's Avatar
ORIGINAL: saabpower
How much smoke? If it does not make it more than 1-2 feet from the tailpipe before disappearing then it is likely justwater vapor condensing against the cold air and isnothing to be concearned about.
However if it is actual smokeit will form more of a cloud that is usually visiblewhen looking out the back window from inside the car.Smoke out the tailpipeis NOT normal. It is usually caused by oil leaking pastworn turbo bearings while the car sits (off). When you start the car the collected oil gets blown through the engine and burns causing the telltale "blue oil smoke." If this is the case it is likely that your turbo is in need of a rebuild.
Canada_Saab
Nov 6, 2016 09:36 AM
Susanna Conway
Oct 23, 2016 03:46 PM
mckenzig
1974-1994 900
Jan 3, 2014 01:16 AM
jawadelanis
Aug 26, 2010 02:34 PM
rallyking13
Jul 27, 2010 03:03 PM
