Window has come loose
Old Jul 8, 2009 | 02:50 PM
davesloan's Avatar
Default Window has come loose
Thanks for any advice.
Here's the dealio:
  • I have a Saab 9-3
  • The driver's side window has come loose. The window can be moved up and down by gripping it by hand, but not by power.
  • The small motor seems to be working fine. The window appears to be disengaged from the small motor and clamps/cables within the door.
  • I have figured how to access inside the door. I removed the door liner.
  • Now that I can see in there, I'm looking at some cables and some white plastic clamp type thingies.
Just not sure what should be attached to the bottom of the window, and how. I'm looking for some help on what it should look like in there, what should be attached to what, and what parts need to be inspected and possibly replaced.
thanks!
Old Oct 28, 2009 | 04:20 PM
haroldcalvert's Avatar
i just replaced the rear window in a 93, the plastic piece which travels up and down via the cable and motor should ride in the alum track that is friction cit to the lower portion of the window. i had a land rover where one of these plastic pices broke while driving and the window fell.
Old Nov 28, 2009 | 10:51 PM
gatr2000's Avatar
i now have two windows out .. one rear window is being held up with a jumbo pink eraser bar(yes a pencil eraser) the other is my driver side window....saab tends to have the stupidest things break..let me know when you figure this out...i am addressing other issues with the car more serious right now.
Autogeek
Aug 10, 2019 09:34 PM
Aerohead
Sep 29, 2015 01:42 PM
denny09
Feb 7, 2011 06:29 AM
sheather17
Nov 17, 2009 07:46 AM
Sad Seller
Sep 20, 2007 03:33 PM
