engine stall on idle
Old Apr 13, 2008 | 11:21 AM
nbsman's Avatar
Default engine stall on idle
This happends once or twice a week ,but yesterday it happened 4 times it just shuts off on the red light ,so on the idle (never happened when car is in motion) rpm's are dropping down from 1000 and it seems like engine don't have enough fuel or air in the mixture,sometimes rpms dropping down and engine is almost stalling but it gets back spinning at 1500 2000 for the first 2 seconds or so then returns to 1000.It mostly happends right after stoping at the red light,when i push brakes ,right before stop rpms arer getting lower than 1000.
I'm trying to figure this out ,have new fuel filter to change ,but t most likely that engine don't have enought of air or it's pressure,there's sucking noize that my mechanic noticed when i took my car fo the checkup,maybe something wrong with MAF censor ,i'm not too familiar with saab engines and don't have repair manual ,so maybe you can help me figure it out. Thanks
Old Apr 13, 2008 | 12:27 PM
Default RE: engine stall on idle
clean the IACV first
Old Apr 13, 2008 | 12:43 PM
nbsman's Avatar
So i think this is Idle Air Control Valve ,but where it located?
Old Apr 13, 2008 | 01:53 PM
When you take the plastic cover off it's right next to the TB, looks like a silver cylinder with two hoses and a connector attached to it. You can't miss it.
Old Apr 13, 2008 | 06:04 PM
nbsman's Avatar
went to look at it
Old Apr 15, 2008 | 10:33 PM
nbsman's Avatar
So cleaned it up with carb cleaner ,it was pretty dirty,broke PVC nipple at the same time ,(thanks god that wasn't serious),when started engine it was idling perfectly,but on my way home engine stalled once when iwas on the red light ,so maybe i should look for pressure leak or something else
Old Apr 16, 2008 | 07:29 AM
Well while your PCV is broken you DO have a vacuum leak, however that should actually make the car rev higher... run a can of seafoam through the gas tank and see if anything changes. Also check your plugs...
Old Apr 16, 2008 | 09:14 PM
nbsman's Avatar
seafoam is already there ,pvc nipple holds on crazy glue (still),new parts are about to come.
What i noticed is when i'm pressing the brake rpms going down in 2 times out of 5.Will take it to the mechanic this week will se what he'll say.
Old Jun 15, 2008 | 10:02 PM
gatr2000's Avatar
same issue ..how can i raise the idle...car just rattles at 400 rpm at every stop.
thx
gatr2000
Old Jun 25, 2008 | 11:50 PM
gatr2000's Avatar
no way to adjust idle? its like aguaranteed migrane after an hour at400 rpm
thx gtr
Canada_Saab
Nov 6, 2016 09:36 AM
parkermoto
1974-1994 900
Sep 28, 2016 11:28 PM
ThePoisonDonut
Sep 22, 2016 07:49 AM
Murph
1994-1994 900
Feb 10, 2016 06:51 AM
info2
May 14, 2013 07:16 AM
