A/C Problem
Old Sep 14, 2008 | 03:02 PM
tifdb.com's Avatar
Default A/C Problem
Hello everyone,
i have a 2000 9-5 2.3t.
the problem im having is that when i put on the A/C the passenger side gets the COLD air and the driver side gets warm, vise-versa when i put the heat on. im not that car saavy so im not sure what to look for, but at the same time if i can do this fix myself that would be better...
please help
_h
http://www.tifdb.com
Old Sep 15, 2008 | 08:30 PM
tifdb.com's Avatar
Default RE: A/C Problem
OK... in addition to the A/C problem below, i also have that musky odor when i turn the heat on and it just intensifies... i wanted to check the cabin filter? i think its called, but i first have to remove the wiper arms inorder to remove the plastic panelling. my second problem is that im not sure how to tak eoff the wiper arms. ive unscrewed the bolts and tried to pry and wiggle the arms off with no luck... any idea on how to remove them?
_h
Old Sep 23, 2008 | 11:35 AM
Norskiglass's Avatar
A bearing puller is handy however you may give a little shot of lubricant and a slight "bop" with a rubber mallet while pulling up on the wiper arm. BTW I have never looked into replacing the cabin filter however I may of over looked it as I inspected the brushes on the blower fan.....
Enjoy!
Chip
Nov 1, 2025 07:40 PM
swede900
Dec 14, 2006 12:22 AM
Sparkplugs.com
Dec 1, 2006 04:53 PM
questions
Oct 14, 2006 06:11 AM
pp
Jan 25, 2006 12:44 PM
