engine code P1110
Old Jan 4, 2008 | 06:31 PM
99a6q's Avatar
Default engine code P1110
I have an 01 saab 9-5 4cyl turbo and my check engine light came on. The codes I pulled were P1110 and the code reader says "No definition avaliable" Does anybody know what this code means? I have my own personal scan tool and tried erasing it once and it came back.....any advice here would be helpful, thanks in advance!
Old Jan 4, 2008 | 07:59 PM
Default RE: engine code P1110
Most likely this is the BPV. Easy to replace, but expensive in itself. Much better to swap one with a smilar car to check first and only them purchase a new one. This code indicated boost pressure fluctuations. Could also be a vacuum leak, but not likely.
Old Jan 23, 2008 | 11:30 AM
joeyfrisco's Avatar
I have an 02 Saab 9-5 4 cyl, 2.3t linear.
I actually had my CEL go on last friday and I checked the code yesterday and it is the same (P1110). I've checked forums about the code and I don't have the usual symptoms of the BPV problem (boost either being totally engaged or off). Actually, the car and turbo seem to be working fine/normal. The car may be slightly idling rough, but then again, if it is, it is subtle enough where I am not certain. Does anyone know what would be the symptoms of a vacuum leak or another possible cause of the error?
Thanks,
-Joe
Old Jan 23, 2008 | 02:34 PM
symptoms of vacuum leaks...rough idle, increased fuel consumption, wierd nosies under the hood....OR no symptoms at all...when in doubt just replace all the vacuum hoses with new silicone hoses...these things do dryrot and they are a consumable item.
emilia81
Dec 3, 2015 07:20 PM
green95
Jul 30, 2013 05:27 AM
missriot22
Jan 14, 2011 05:50 PM
jerickson
5
Jan 10, 2011 05:33 PM
Asldhjkf
May 24, 2010 05:37 PM
