Speedometer stops while driving
Old Jun 30, 2007 | 06:47 AM
katysaab9917's Avatar
Default Speedometer stops while driving
I have a 99 95 that has recently started to act a little weird (or should I say, more weird than usual!). Anyway, I noticed that after driving for about 5 minutes, the speedometer drops to zero and the ABS and brake lights come on. The next day the same thing happens. Everything is fine for the first few minutes, then it repeats. My guess is that the speedometer and brake lights are linked to a sensor on one of the wheels. Is that correct? If so, is it just a loose connection. Seems like there's something that must be overheating. So those are just some of my guesses. Now I'm turning to the experts! Please help...I need to get this fixed so I can trade this thing in! Thanks.
Old Jun 30, 2007 | 08:51 AM
Default RE: Speedometer stops while driving
clean out the ABS sensor connetors and if that doesn't help the VSS might need to be cleaned.
Old Jul 1, 2007 | 04:35 PM
Roto,
Throw me a bone! I don't know where to find the sensor or what it looks like.
Old Jul 1, 2007 | 09:20 PM
the ABS sensors are easy to find - there's a connector at each hub. As far as the VSS goes I can't really help you. I know it's screwed into the transmission, but there are also a few other things screwed into that aside from VSS...
Canada_Saab
Nov 6, 2016 09:36 AM
Susanna Conway
Oct 23, 2016 03:46 PM
dubs1013
Jul 18, 2011 06:49 PM
gatr2000
Jan 29, 2011 12:19 PM
bojib
Mar 8, 2008 07:31 PM
