Check Engien Light
Old Feb 2, 2009 | 03:16 AM
Docen's Avatar
Default Check Engien Light
Hei, my check engien light is worker in my car. and I have found out that it's p0130 - Oxygen sensor (OS) or OS circuit.
Also my CO% gass whas to high, 1,57 % to be exactly, and should be 0,5 %
Can all this come from the Lamdasond?
Or do some one in her know what det problemt can be?
The spec's on my var :
3" all the way from the turbo. New Intercooler. Open Air filter K&N. 0,5 Bar Turbo boost.
Sorry for bad language
Mvh
Old Feb 2, 2009 | 07:18 AM
Default RE: Check Engien Light
Do you still have a catalytic converter on your car? Yes, the O2 sensor is probably at fault here, but if you don't have a cat it might also be the cause.
Old Feb 2, 2009 | 10:20 AM
Docen's Avatar
Yes I have cat on my car, and I have checked every silikon house for leeks on the car, and have found no one, but I don't want to by new lamda if it's not the lamda who is broken, you get me?
The car works perfectly normal, I dont notis anything at all when I am driven, exept that its using VERY mutch Gasolin !!!!!! The drivingcomputer goes of the hills with the numbers.
Again, sorry for my bad English.
Old Feb 2, 2009 | 10:43 AM
It is possible that this code is indicating something else. Try to check the 02 sensor wires for continuity with a multimeter. Also I'd check the fuel pressure to see if it's low by any chance. That code can be triggered by that.
Old Feb 2, 2009 | 11:07 AM
Docen's Avatar
Okei, how can I check the fuel pressure? Do I ned anny special tool? or do I need a Gauge?
Old Feb 2, 2009 | 11:36 AM
yeah, you need a gauge. There's a valve that you can attach a gauge to. The location varies, but it's either at the fuel rail or at the fuel pressure regulator.
Old Feb 2, 2009 | 12:29 PM
Saab Fahrer's Avatar
Hello Docen. If you don't mind me asking, what is your mother language?
Old Feb 2, 2009 | 01:38 PM
Docen's Avatar
Okei, Thanks Roto
My Mother language is Norwegian
just one question:
If this problems that you are saying I should check is allright. Then it's
guaranteed that it's the Lamda, 02 sensor?
Old Feb 2, 2009 | 02:11 PM
Nothing is ever guaranteed, but it may be the case...also try to take the sensor out and wire-brush the bung. It could just be a bad ground.
Old Feb 2, 2009 | 03:01 PM
boostpowered's Avatar
could it be the amm causing him trouble with codes
