1999 Saab 9-3 cutting out?? help!!
Old Dec 4, 2009 | 08:33 PM
seely9-3's Avatar
Angry 1999 Saab 9-3 cutting out?? help!!
i have a 1999 Saab 9-3 SE and when i push the gas down all the way and the turbo pressure goes up, the stock gauge actually goes into the red and its like there is too much pressure or something. the car almost comes to a complete stop but it doesn't turn off or anything. as long as i keep it so that the turbo gauge doesn't go into the red it runs fine. i was just wondering if anyone thought they knew what was happening, like some sort of limitor for the turbo that is broken?
Old Dec 5, 2009 | 08:55 AM
Your wastegate is probably stuck and you're hitting boost cut. Take off the heatshield over the turbo and try to wiggly the wastegate actulator arm. It should be pretty stiff. but you should be able to move it by hand. If it moves than probably the boost control valve is dead or you have a massive vacuum leak somewhere. To eliminate the astegate completely you can take a short piece of vacuum hose and connect the nipple on the wastegate to the nipple on the cold side of the turbo and try to run that way (don't forget to plug up the hoses that you took off.
This is what the wastegate looks like:
BrianMiG
Jul 3, 2010 04:21 PM
nickssaab09
Jun 30, 2010 06:22 PM
SilentButDeadly
Nov 15, 2009 09:55 PM
NickDave
1974-1994 900
Jul 12, 2009 04:23 PM
rbuscemi
Dec 20, 2008 10:01 PM
