95 starting issues
Old Aug 9, 2014 | 11:31 AM
Lee2003's Avatar
Default 95 starting issues
Not sure if twice or key, but starter does not engage when key turned, but dash lights up. key doesn't work, manual lock does not work, power seats and trunk release do not work. relay under passenger seat clicking. replaced battery and checked fuses. Worked one night ad next morning had all the problems. Can someone give me a starting point?
Old Oct 4, 2014 | 05:36 PM
Massauto's Avatar
Did you ever get this sorted out? If yes, what was it? Thanks. Ron
Old Oct 27, 2014 | 10:40 PM
anjleena123's Avatar
Thanks Ron for the nice sharing i think you are right and i agreed with you
Old Feb 25, 2015 | 04:24 AM
robinsonparker's Avatar
The reason that i recognised that the Hall sensor wires were rotten.The Hall sensor is in the distrubutor for the turbo C900. The non turbo has a crank sensor not a hall sensor.
Ok, here's the thing, car gets hot the fan goes off, it shakes the car, shakes the distributor hall sensor wires shuts down car, since your hall sensor wires are rotten to the core. Or, if you will, you park car, fan goes off, shakes it, you come back to it, it won't start. You hall sensor wires are rotten to the core. You can fix it yoursef by rewiring the hall sensor or you buy a used or rebuild distributor.
vcampbell
Dec 23, 2013 05:22 AM
Nate
Apr 2, 2011 07:22 PM
jdev
Feb 19, 2011 11:56 PM
tiodecember
Sep 23, 2010 08:50 AM
nicksaab0993
Jul 27, 2010 10:16 PM
