Antenna Replacement
Old Jun 7, 2009 | 01:50 PM
thanser's Avatar
Default Antenna Replacement
This is normally an easy task, and I've even done it on other vehicles in the past.
I have a replacement mast ready to go, but after removing the retaining nut I can not remove the old antenna mast, after switching the radio on and off again.
There seems to be a sleeve on the outside that has a spring tab that doesn't allow it come OUT, but I can see how it could be pressed down into place. I can see this sleeve on the new replacement antenna mast I picked up at the parts department.
So how do I remove the old antenna mast, without tearing out the motor assembly from inside the trunk? There has to be a simple trick to removing that sleeve.
Thanks!
Old Jun 7, 2009 | 07:20 PM
Meh, I usually just take the whole thing out... its not that time consuming.
Roto
Oct 24, 2015 09:22 AM
tp38
Jan 19, 2008 09:26 PM
Swede115
Apr 29, 2007 11:18 AM
Roto
Feb 20, 2007 10:27 PM
