heater doesn't get hot
Old Mar 4, 2007 | 09:43 PM
desp4him's Avatar
Default heater doesn't get hot
I have a 1996 9000 turbo - just had the thermostat changed and my heater still hardly blows out hot air. Any ideas?
Old Mar 4, 2007 | 11:50 PM
Default RE: heater doesn't get hot
Check your coolant level first. May be even bleed the system
Old Mar 5, 2007 | 05:14 PM
Des's Avatar
Des
Does the car run at the correct temp ? if so then your new stat is ok.
You may have created an air lock in the heater system which is easy to do.
You should fill your system slowly and when nearly full start engine and turn heater on to Max and then fill to level.
Replace cap on cooling system and run until temp shows normal operating temp.
Turn off and allow to cool for 1/2Hr or until safe to remove filler cap and recheck level.
Another answer is to flush the system with a cleaner from your motorist centre with the heater set to full and fan on, drain and refill.
I hope this helps you out.
Des
Old Mar 6, 2007 | 05:44 PM
desp4him's Avatar
Thanks. We do have enough coolant in it. I will try the latest suggestion.
0195reed
Dec 3, 2015 05:44 PM
nbsman
22
Feb 1, 2014 09:01 PM
Mr_boondoggle
Dec 29, 2008 09:52 AM
