-   -   Help... "97" 900 se Turb. .....problems.. (https://saabforums.com/forum/general-auto-related-help-area-8/help-%2297%22-900-se-turb-problems-287/)
swede900 Jul 28, 2006 12:04 PM
Please give me some advice to my problem......I have a 97 900SE Turbo 5spd .....when the engine revs between 1800-2500 rpm the engine jerks...I thought it was the sparks, so I replaced the Bosch Super risistor plugs.....but still having the problem.....Initiallly when i first start the engine I don't see this jerking motion, but after driving for about 3-4 miles the problems starts.....Please help...My Neck Hurts SOOOO Much :([:'(]From All the Jerking from the engine......Desperate........Also does anyone know about putting Dielectric Grease into the DI unit ???????? :eek:
Thanks for any inputs......
SecondSaab Dec 14, 2006 12:22 AM
RE: Help... "97" 900 se Turb. .....problems..
Well i had the same problem :(first thing you did wrong was put in bosch plugs. thats a no no.. NGK V-Power BCPR6E-11 are the correct plugs for the DI yes Dielectric grease is a must and correct gap .040 theDi sends a signal to the PCM to ajust and with bosh plugs or the rong gap can really mess things up for the DI ifi were you i would do that first then if thats not it. Take and remove the DIafter motor has been OFFfor a minute or two and flip over so the 4 tails are facing upplace the plugs in ang run a wire from each thred to the negitive battery.. Then Crank over to see park if you do not see onespark yourDI is gone try at least 3 time to insure as for the DI its avaible at CarQuestfor $420 big price tag and comes in a GM box although its easy to replace its costly if you end up replaceing the DI contact me and i will give complete directionsfor replaceing and torx specs for everything. Good Luck!
Ed
850-766-3182
