Radiator Removal
I am new to the forums and I did not see a post yet about radiator replacement. I have a 1999 93 turbo and I am almost finished replacing the radiator. I am having some problems getting the actual radiator out. I have the fan shroud off. The A/C is unbolted and all the hoses are disconnected. Radiator still won't budge on the driver side. Any help would be much appreciated. Thanks, Josh
RE: Radiator Removal
hi hope this helps
Removal and Installation Instructions for Saab 900-93 Radiators STEP1 Remove the Intercooler STEP2 Remove the grille STEP3 Remove the oil cooler (certain cars) and hang it so the hoses are not bent STEP4 Remove the AC condenser from the radiator STEP5 Disconnect and remove the battery STEP6 Drain the coolant. Remove the lid on the expansion tank to speed up the draining STEP7 Remove the bypass hose together with the intake hose on Turbo Cars STEP8 Remove the upper radiator hoses from the radiator STEP9 Remove the radiator fan's electrical connections STEP10 Remove the servo pump's oil pipe and the Radiator breather hose clips & turn oil hose to one side STEP11 Remove the 2 screws on the fan Shroud STEP12 Remove the transmission oil pipes by the oil cooler & the screw holding pipe to radiator STEP13 Remove the lower radiator hose, remove clamps which hold the radiator to cross member and pull up the radiator from the rubber mountings so that the clip for the A/C compressor's cable can be undone. STEP14 Lift out the radiator. Refit in Reverse |
