07 Saab 93 Drivers Side Headlight bulb replacement
Old May 13, 2010 | 09:25 AM
CyborgTodd's Avatar
Default 07 Saab 93 Drivers Side Headlight bulb replacement
This will sound dumb, but really, it's not meant to.
I know that you turn the rubber cover to remove it and access the bulb. I know that you twist the bulb to remove it and unplug it.
I get all of that.
How the heck to you get your hands between the windshield washer receptacle, the fuse box and the light? I don't think my 2 year old could get her hand in there.
Do I have to remove the housing to replace the light bulb? FWIW, it is the drivers side low beam light.
Thanks.
Old May 22, 2010 | 07:11 PM
IGUANA's Avatar
Default Tight fit
Remove the top battery cover. Pull the neck off the washer tank. Remove the front engine mini fuse box (between the battery and headlight area) by releaseing the clip from the battery surround.Install new bulb and reassemble. Now the other part.... Check that the pig tail is not burnt, bare wires. If so they are cheap at your local dealer. About $17.00. If light still doesn't work....In the larger fuse box (next to the battery) you will find an orange relay. Wiggle it. If the light comes on you will need to replace that relay to the tune of about $150.00. Good Luck
Old Jul 1, 2010 | 09:47 AM
CyborgTodd's Avatar
Iguana, Thanks man, that worked great!
raboni
Oct 16, 2012 02:43 AM
Watagatapitusbry
Oct 6, 2011 09:31 PM
bojib
Mar 4, 2008 06:13 AM
dc_prep
Oct 29, 2007 07:57 PM
colliefan442
Oct 12, 2007 07:43 PM
