2008 9-3 check engine light and rough engine idle
Old Nov 29, 2011 | 11:10 AM
jhan's Avatar
Default 2008 9-3 check engine light and rough engine idle
I've got 110,00 km mostly highway. Check engine light went on for first time, had it examined and ignition coil of cylinger no. 1 replaced. Also, dirty fuel injectors cleaned. After a couple days, check engine light on again and rough engine idle when engine is cold with clattering sound; noise disappears when the clutch is depressed. Took it in and had code read (don't know code, but mechanic said it was indicating improper combustion). Cleaned injectors again and reset computer. Next day, check engine on again and still have rough idle with cold engine. Mechanic says could be mass airflow sensor or spark plugs. Anybody else experience this or know what may be wrong?
Old Nov 7, 2012 | 11:55 AM
Weimfan's Avatar
Default Same problem
I'm currently having the same problem. What did you ultimately find the problem was?
Old Nov 8, 2012 | 10:00 PM
jhan's Avatar
It ended up being that the engine cylinder intake valves were so thinned out that there was pressure leakage. It was an expensive repair. I was told by the mechanic that using regular grade fuel could be the cause. I am now using premium gas only. It's been 30,000 km and no engine light.
Old Nov 9, 2012 | 12:09 PM
Weimfan's Avatar
Default Thank you
I hope that isn't the problem but I suspect it is. I'm even at the same 110,000 km you were at.
Old Nov 10, 2012 | 12:42 PM
jhan's Avatar
I'd get it checked out. The SAAB mechanic I went to see downtown Toronto was surprised that the intake valves wore down at such a low odometer reading. He normally encounters the valve problem with 200K plus vehicles.
shanewilsonjr
Jan 24, 2015 06:25 AM
kbradford70
May 1, 2011 12:10 PM
eisenb11
Oct 17, 2007 08:49 PM
Meinhaj Hussain
Aug 6, 2007 12:14 PM
jheldt17
Aug 5, 2007 01:32 AM
