Brake Pedal Pushes Hard
Old Mar 18, 2015 | 04:30 PM
jackraider's Avatar
Default Brake Pedal Pushes Hard
Hi. I have a 2000 Saab 93 with 196,000 miles on it. Recently, the brake pedal has gotten very difficult to press. The initial part of the pedal travel is pretty normal, but when I press farther, as I'm getting closer to actually stopping, it's like there are no power brakes at all. I can also hear what seems to be air bleeding out from under the dash as I press the pedal. I suspect the brake booster, but that was replaced only 2 years ago (40,000 miles) with a new booster (part alone cost $358). They also put in a used master cylinder at the same time. The symptom then was that the brake pedal would depress, but wouldn't return, so I had to pull it back with my foot. This time, the pedal just presses hard.
Any ideas on if there could be another cause?
Thanks for the help.
nmbutter73
Aug 27, 2012 08:53 PM
saabguy1996
Nov 4, 2010 02:27 PM
modrod
Sep 5, 2007 01:04 AM
Tetzlaffino
Jul 11, 2007 09:01 AM
nhrvatin
Dec 16, 2006 05:31 PM
