How to change tie-rods?
Old May 2, 2009 | 08:31 PM
playboy00786's Avatar
Default How to change tie-rods?
Does anybody have a guide on how to change the tie-rods inner and outter or can anybody tell me how hard it is?
Old May 6, 2009 | 06:04 PM
The outer rods are pretty straightforward. Undo the pin, unbolt it from the knuckle, separate it with either a fork or a puller and than screw off the tie rod end. Why do you need to do the inner tie rods?
Old May 11, 2009 | 03:28 PM
I took it into the dealer to get it aligned and they told me they couldnt do it because i needed new tie rods. I told them i would do them myself so i asked them if i need to replace the inner and outer and they said yes. Should I replace them or just replace the outer...or maybe just replace the inner bushings and outer tie rods. Which rout should i go? How hard are the inner bushings to replace?
Old May 11, 2009 | 03:34 PM
You need to know why they told you they need replacement. I bet the adjusting nut is froze. Take the front wheels off and inspect the tie rods. I'd replace the outers regardless, but if the inners have the adjusting nut is frozen in them you might need to heat them up a little and get it out. After which you can clean it up, soak it in oil and use anti seize. It'll save you money on parts and you will know for sure what needs to be done and what doesn't.
Old May 11, 2009 | 03:40 PM
how hard/easy is it to get to the inners? Im actually doing this for a friend so i havent been able to look at it yet. I just trying to gather all the information i can before i tackle it.
Old May 11, 2009 | 04:06 PM
what year is it?
Old May 11, 2009 | 04:08 PM
its a 99
Old May 11, 2009 | 04:21 PM
Open the hood and from the driver's side look at the steering back...you'll see two bolts...
vladdavis
Apr 16, 2015 03:56 PM
shanewilsonjr
Feb 23, 2015 08:30 AM
ECarr
May 25, 2012 08:52 AM
dgroet
Jul 29, 2010 08:20 AM
tiodecember
Jun 30, 2010 02:29 PM
