-   -   missing vaccum hose (https://saabforums.com/forum/saab-9-3-11/missing-vaccum-hose-723/)
josh_d87 Oct 26, 2007 07:29 PM
missing vaccum hose
hello i have a problem with my '99 saab 9-3 i dont know much about cars but i will try to explain it as best i can in hopes that someone can tell me what it is, there is a vacuum hose that is supposed to be connected to the intake right where the intake pipe connects to the engine, it is i believe the onlyvacuume hose that comes out thepassenger side of the intake. well that hose is gone.
i started my car this morning and it was running really rough. i looked in the engine and could hear the hiss of air, wich lead me to the very small part of hose was hanging however i could not for the life of me find the rest of the hose. what i need to know is what does it go to. it is, like i said, on the passenger side of the intake, it points some what twords the rear of the car. if anyone could help me identify this, that would be great.
thank you.
Roto Oct 27, 2007 01:20 PM
RE: missing vaccum hose
can you take a picture? Did your car throw a check engine light? I suspect it's the MAP sensor hose, the sensor is attached to the strut tower bar on the passenger side...
josh_d87 Oct 28, 2007 05:12 PM
yeah it did have a check engine light for a bit before it broke completely. i looked at it and it isnt the line to the MAP sensor. that one is still connected its further back on the throttle body than that. i dont have a camara but i am trying to find one, hopefully i can get a pic up by tonight. thanks for your help.
josh_d87 Oct 28, 2007 07:01 PM
ok here are the pics i hope they are good enough to help. i hope i did this right.
[IMG]local://upfiles/1117/A3FBCBE48BD549E9B01500798872190C.jpg[/IMG]
Roto Oct 29, 2007 08:46 AM
oooohhhh that....look next to the wheel well for the remains of it.
josh_d87 Oct 29, 2007 05:22 PM
i looked everywhere and i cant find the rest of the hose, maybe it got ripped off somewhere down the line. what is it supposed to connect to? maybe i can find it that way.
Roto Oct 29, 2007 06:34 PM
well I'd lie if I said what the thing is..looks like part of the emissions system...connects to some sort of a valve located on the passanger side wheel well. I'll look into in the WIS, but I hadn't had much luck finnding specific things in there...
josh_d87 Oct 29, 2007 06:40 PM
is it inside the wheel well, or in the engine compartment( like under the air box)?
Roto Oct 29, 2007 07:27 PM
in the compartment, like behind the shock tower...
Roto Oct 30, 2007 12:11 PM
It's supposed to connect to the EVAP valve and there should be another hose from the valve going to the charcoal canister.
