One rear DRL won't turn off
Old Aug 7, 2014 | 09:44 AM
Bpeirson's Avatar
Red face One rear DRL won't turn off
I am having an on and off issue with my 2005 Saab 9-3 arc convertible. The drivers side rear daytime running light remains on after the car is turned off and the key is removed. It doesn't turn off when fiddling with the headlight on off switch. The only way to turn it off it to pull the fuse. Everything else seems to be functioning correctly except for a pinch sensor on the passenger side front window.
My mechanic's solution was to remove the bulb and leave it out which results in an annoying "light failure" notification every time I turn the car on. Has anyone else had this issue? Or does anyone have any ideas for things I could try?
Thanks!!
Old Sep 6, 2014 | 04:59 AM
myfirstsaab93's Avatar
Have you left an indicator on possible, on vauxhalls leaving the indicator on acts as a parking light.
Old Feb 16, 2015 | 04:16 AM
044hnoor's Avatar
___________________
Are you interested in Pass4sure 70-410 Get our self paced a+ book itil study packages to pass your rasmussen without any http://en.wikipedia.org/wiki/Hobe_Sound_Bible_College lsat.
kyblusaab
Jan 21, 2011 10:27 PM
Ray Bell
Mar 4, 2010 04:47 AM
blubirdinny
Feb 19, 2010 07:46 PM
sheather17
Nov 17, 2009 07:46 AM
Saab Fahrer
Mar 12, 2009 04:53 PM
